I have a hitachi seiki ht20 with a crt monitor, cr5470ye to be exact.. Bought a used monitor was supposed to work but didn’t, sent it back got a lcd for my replacement of my crt monitor difference is it was for a ht25 and not a hot but both had the cr5470ye monitor her is a pic below the hookups are different both 3 wires each with a green/yellow wire can I make this work?
HelloI have a hitachi seiki ht20 with a crt monitor, cr5470ye to be exact.. Bought a used monitor was supposed to work but didn’t, sent it back got a lcd for my replacement of my crt monitor difference is it was for a ht25 and not a hot but both had the cr5470ye monitor her is a pic below the hookups are different both 3 wires each with a green/yellow wire can I make this work?
That is the power wire. The yellow/green is the earth ground and the other two are the AC. As long as you keep them the same pinout it will work.
