- Hitachi Seicos VM4III 18iM - Rigid Tapping Parameter Setup
I have a machine of Hitachi Seicos VM4III using Fanuc 18iM + Seicos OS.
Now, it can not using Rigid Tapping.
When I checked parameter of rigid tapping, i saw it have more parameters related rigid tapping.
But I don't know how to setup them.
Pls see attachment and help me if you can.
Re: Hitachi Seicos VM4III 18iM - Rigid Tapping Parameter Setup
Parameter setup looks very much like most Hitachi Seiki's
Hitachi do not use M code for tapping
Call line is G84.1 Z-14. R 3. (example) and ends with G80 as other drilling cycles
Thank you so much. I will try this way.
- You may not post replies
- You may not edit your posts
Forum Rules
