- Need Help!- HiCell 23 Turret Not Indexing!
Hello!
I have a CA23 HiCell 23 Lathe, and the turret will not index in Program or MDI mode!
The turret will index just fine in manual mode, however it will not move via program. It will get to the Txxyy00 code, and eventually timeout.
Has anyone ran into this issue before?
Thank you,
Casey
Re: HiCell 23 Turret Not Indexing!
normally some sort of door interlock fault, because turret will not index in auto mode if door is not closed
- You may not post replies
- You may not edit your posts
Forum Rules
