VK 45 II NUMC BOARD ERROR
Results 1 to 2 of 2
Thread: VK 45 II NUMC BOARD ERROR
    Sep 2008
    Romania
    Default VK 45 II NUMC BOARD ERROR
    Hello,
    I am having a problem with my VK 45 II with seicos M3 controller. It started a couple of weeks ago showing randomly NUMC board error on a daily basis both when the machine was running a part or on standby. This made the machine go on e stop.
    Starting today when ever I press MDY button on the panel the error appears :NUMC SYSTEM FAIL, Software error occurs in the NUMC board . All the other machine functions and buttons work ok, but I can't start a program in memory mode.
    The machine data and parameters are ok, I even scrolled trough the ladder diagram to check for changes but nothing. When the error occurs there are 2 red led s on the NUMC board number 3 and 5.
    Thank you
    Member shas595's Avatar
    Dec 2009
    Default Re: VK 45 II NUMC BOARD ERROR
    Hello
    the NUMC is failing based on what you are describing (and what the controller is telling you). This is a common fail-point within the SIII controller. Best thing is to backup you NC now;
    LED3 is FAIL and LED 5 is SOFTALM
    If you need further assistance please PM me and I will help; there is a process that needs to be done before swapping parts
    Its also possible the NUMC software is failing that is on the EPROM ( I have seen it only once or twice in my experience) but its a possibility.
    John
    Mar 2006
    Hello John,
    Hitachi Seiki periodic alarm 1107 occurring in the Seicos M3 indicating NUMC System Fail - CPU HLT occurs in the system board. Is it worth reseating the board and retrying thanks? If so, I would have to back up as mentioned above, I think you mentioned that there is a procedure. regards Dave
    Apr 2014
    Did you find a resolution to the NUMC fail
