Hitachi seiki vm40 spindle wont go over 3000rpm
Results 1 to 3 of 3
Thread: Hitachi seiki vm40 spindle wont go over 3000rpm
    Member Craig1971's Avatar
    Aug 2020
    Default Hitachi seiki vm40 spindle wont go over 3000rpm
    Hi i hope some one can help. I have a Hitachi seiki vm40 with Seikos control, it has Mitsubishi 6000rpm spindle motor and drive. It will not go above approx 2900rpm. No alarms, no load on spindle, no noises. Control working perfectly otherwise. Can some one give me some helpful advice?
    Thanks in advance,
    Craig.
    Default Re: Hitachi seiki vm40 spindle wont go over 3000rpm
    Do you have a winding's selector? Sounds like you are not getting into the H windings? Also, check the drive parameters? Did this happen all of a sudden?
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by Craig1971 View Post
    Thanks in advance,
    Craig.
    If it is using frequency inverter, then you can check its setting for highest speed, is it match with 6000rpm speed?
    Or you can check the electronic gear ratio setting.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
