- VK45 II - Direct Tapping
Hi ,
Is possible to disable the direct tapping on VK45 II, with Seicos III ?
I never tap with this machine, and i use it only for some works
Sometimes, like a years ago, the machine won't start, and gives me 867 error.
I never found the cause of error. Maybe if i disable the direct tapping and the machine "don't check this axis", can i work normally.
Enrico
- You may not post replies
- You may not edit your posts
Forum Rules
