Torno Hitachi seiki 5NE-1100 turret fails
Results 1 to 7 of 7
Thread: Torno Hitachi seiki 5NE-1100 turret fails
    Jul 2014
    Default Torno Hitachi seiki 5NE-1100 turret fails
    Dear, I need your help I have a lathe hitachi seiki 5ne-1100 which does not obey the orders for the change of tools, if someone happened something similar please leave your comments, or if you can support me with the manual electrical wiring I would appreciate it a lot.
    Jun 2007
    SW Wis USA
    Default Re: Torno Hitachi seiki 5NE-1100 turret fails
    Did it stop working suddenly or did you buy it not working?
    How did you try to change tools?
    Ed.
    Jul 2014
    Quote Originally Posted by atex57 View Post
    Ed.
    two months ago I was ok ', over time it started to fail more and more. Now it only works a couple of times in the morning. I've tried it in MDI, MANUAL and PROGRAM mode
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by APTHOR View Post
    Could be the turret sensor broken, which caused it could not find the correct position to change the tool.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2007
    SW Wis USA
    Can you use MDI and move it around?
    Try using MDI to send turret to X home, as in G28U0 then press the turret index button see if it indexes.
    Ed.
    Jul 2014
    friends I did what you tell me and nothing.
    When the cnc lathe turns on in the morning, it works a couple of times.
    Then I try to move manually and by MDI and it does not move anymore, it does not work, the worst thing is that it does not alarm me.
    S.O.S
  7. #7
    Jun 2007
    SW Wis USA
    S.O.S
    Are you doing the complete homing process? Home X, Home Z, Home tailstock quill, and shifting headstock in MDI mode?
    My lathe started acting up sometimes then all the time. It was a bad connection on a cable in the back cabinet. Shut off the power then disconnect each cable and reconnect it, do this to all cables and try again.
    Ed.
