- Need Help!- VS50 12,000 RPM SPindle
Does Anyone know what the bearing numbers are for the spindle in a VS50 with a 12,000 rpm spindle with through the tool coolant?
DMG Mori needs part numbers and they have to check with Japan for part availability and cost. I would like to find these bearings without getting them through Mori.
I'm sure they are common Tapered thrust bearings. There are two sets in the spindle and 1 on the top of the spindle above the motor Armature. DMG Mori in Cinci
does not have any documentation for this old machine
Re: VS50 12,000 RPM SPindle
Bryan
ill send you a PM so I can help you out better. They are matched pair KOYOs -
John
- You may not post replies
- You may not edit your posts
Forum Rules
