Need Help! ATC Alarm Hitachi Seiki 400-3HG
Results 1 to 4 of 4
Thread: ATC Alarm Hitachi Seiki 400-3HG
    Jan 2016
    Default ATC Alarm Hitachi Seiki 400-3HG
    CNC - Fanuc -RB-6
    PMC - B06F
    Loader 2752B06F
    There is no documentation for the machine. this machine settings error, as I understand it.
    Tell me how you can solve the problem. Departure to the fix point for ATC with the help
    of M codes is impossible. In manual mode, ATC does not work the same way.PMC issues 2 errors, but there are no errors in PMC settings. There is only a message
    for the operator that can not be erased.When turning on the machine, the error iconAnyone can help with the documentation or can advise how to solve the problem?
    There is no documentation for the machine. this machine settings error, as I understand it. Tell me how you can solve the problem. Departure to the fix point for ATC with the help of M codes is impossible. In manual mode, ATC does not work the same way.PMC issues 2 errors, but there are no errors in PMC settings. There is only a message for the operator that can not be erased.When turning on the machine, the error iconAnyone can help with the documentation or can advise how to solve the problem.
    Member shas595's Avatar
    Dec 2009
    Default Re: ATC Alarm Hitachi Seiki 400-3HG
    Hello!
    What is the alarm you are getting?
    John
    Jan 2016
    Hi John!
    have 3 alarms:
    S. Arm position data Alarm 2271 adress A17.1(D717.1)
    T-command S arm position alarm 2252 adress A15.2(D715.2)
    S arm turn time over 2270 adress A17.0(D717.0)
    Apr 2013
    mexico
    Quote Originally Posted by Evil_K View Post
    CNC - Fanuc -RB-6
    PMC - B06F
    Loader 2752B06F
    Hello
    Were you able to clear the alarm?
