Problem Control alarms
Results 1 to 4 of 4
Thread: Control alarms
    Mar 2018
    Default Control alarms
    I have a Hitachi Seiki Hi Cell 23 ii with a Seicos 10L control. I purchased this machine used and the back up batteries were dead I replaced the batteries and have the following alarms 699 directory broken, 1421 VID starting error, 1281 X ASC disconnected, 802 PC all Sum check error. Can you help me reboot this control. Thanks Bob
    Registered shas595's Avatar
    Dec 2009
    Default Re: Control alarms
    Bob
    are you still having troubles. Should be no big deal to get back online- let me know!
    John
    Mar 2018
    Quote Originally Posted by shas595 View Post
    Bobare you still having troubles. Should be no big deal to get back online- let me know!John
    Yes it is still down same alarms. Would appreciate any help you can provide. Bob
    Dec 2009
    Bob
    sent you a PM - take a look - there is some info ill send you
    John
    Aug 2013
    I have same problem on directory broken alarm 699. All function manually is ok, only for edit program and command through MDI mode can not be done. Need help please
    hary
Control alarms
Control alarms
