Hitachi TS15 Turret reset procedure - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Hitachi TS15 Turret reset procedure
  1. #21
    Member sting007's Avatar
    Feb 2015
    Quote Originally Posted by docdesigns View Post
    Hi All,
    * I have 1998 Hitachi Seiki TS15 with seicos sigma 21 control.* I recently had the timing belt in the turret start to fray and the belting was pulled from within the middle of the belt wrapping around the pulleys causing it to not index correctly and causing a turret index time out alarm.* I was able to clear the belting and get it working again without removing the whole turret disc and was able to continue using it while I waited for a new belt to come until it happened again for the same reason.* I removed the "tool turret disc"* and get the old belt off and replace it with a new belt.* However, the timing is now off when I index the turret so it wont clamp correctly.* I still have it apart.*
    I cannot find the correct procedure to reset the timing of the turret in my manuals.* Online it seems different models of hitachi seikis use different 3 button combinations and procedures to reset this.* I have seen that I may need to change the 1815 parameter possibly and something else K00.3?
    Does any one know the correct procedure on this lathe?* Any help would be greatly appreciated.
    Thank you
    Would anyone send the procedure
    Sting
  2. #22
    Member shas595's Avatar
    Dec 2009
    Default Re: Hitachi TS15 Turret reset procedure
    Quote Originally Posted by sting007 View Post
    Sting
    PM me your email and I’ll send it
    John
  3. #23
    Member MicroTech1968's Avatar
    Feb 2022
    Hi John, Hope you're available.
    I have hitachi Seiko lathe ts15, 1998 model, having turret problems, it stops while indexing in anticlock direction otherwise working fine.
    Can you help.
    Thanks.
    - - - Updated - - -
    Can you help.
    Thanks.
    - - - Updated - - -
    Can you help.
    Thanks.
  4. #24
    Dec 2009
    Hello
    Send me a PM with your e-mail and I’ll assist
    John
  5. #25
    Member BlackRoad's Avatar
    Oct 2022
    I know this is an older thread, but I am in need of the same procedure.
    Please send to MikeP@AMERM.com
    Thank you.
  6. #26
    Dec 2009
    Hello!
    do you still need help on this
  7. #27
    Member Moonlade's Avatar
    Jun 2023
    I know its an old post but,
    Can you send me the procedure please?
    khernandezloredo@gmail.com
  8. #28
    Member Gverrero's Avatar
    Aug 2023
    Quote Originally Posted by shas595 View Post
    That is a keep relay - so you have to go to Keep Relay 00 and change bit 3 from a 0 to a 1. PM me if you need more help and I can send you a procedure on how to fix this
    John
    Can you send me the procedure please, i have the same problem thanks
    Gverrero.rmz@gmail.com
