- Seicos Slbus error- Fanuc 18-ima
Hello ,
there is a slbus initialization error while power on, machine is vs50 with Fanuc 18-ima ( seicos E-18M)
after change 9988 #4 parameter, machine gave 790 Bram error, we clear it by system table , then this alarm appear , we can not reset yet
anyone help?
video is here https://youtu.be/W0ojfTSu9p8
Re: Seicos Slbus error- Fanuc 18-ima
I know this is old but the issue was likely caused by only partially enabling the data server. That is not the only parameter that needs enabled, also the system table needs to be modified as well.
An SRAM restore prior to fooling around with it will bring the machine back to life.
- You may not post replies
- You may not edit your posts
Forum Rules
