- Hitachi Seiki Hitec Turn HT20SII (Turret Index Error, Alarm # 543)
Turret unable to index manually in Jog. Tried to index by MDI for T0400 (Tool # 4 in cutting position) but alarm no. 543, turret index error appears which is still present after frequent startups (power on and power off).
Help is required for removing alarm no. 543
Thanks in advance
Regards,
Hayder
Re: Hitachi Seiki Hitec Turn HT20SII (Turret Index Error, Alarm # 543)
Hayder - what is the control? I assume this turret is cam driven - so you have turn off the machine - then take off the cover on the side of the turret and manually spin the belt until it indexes to position 1 and the sensors on top are lined up correctly with the index plate.- then follow the steps below:
1. Put turret to position #1 AND POWER ON CONTROL
2. Hold in Buttons SPINDLE STOP / SELECT BUTTON for Dry Run and FEED HOLD Button at the same time. DO NOT RELEASE UNTIL STEP 5 IS PERFORMED.
3. Hit E-Stop
4. Power Off Machine
5. Power On Machine and Press Stand-By
Let me know how it works out
John
HI
If that doesn't work, other ideas
Hi! Did you manage to remove error 543? I also got this error. Can you tell me how to remove it?
If there is an alarm
What is the text ?
Might help us help you.
Could be anything to lock out the index function.
Turret not clamped, not in position, parity error, clamped tooth on tooth on the curvic coupling etc.
- You may not post replies
- You may not edit your posts
Forum Rules
