Hitachi Seiki Repair / Service / Support - Page 8
Page 8 of 8 FirstFirst ... 5678
Results 85 to 91 of 91
Thread: Hitachi Seiki Repair / Service / Support
  1. #85
    Hitachi-parts-usa's Avatar
    Jan 2019
    Waukesha, Wisconsin
    Hello Vanki if you still need help with your VS50 we have parameters as well as loading procedures amongst parts for your Seiki machine. Contact us directly at cybermachinery@gmail.com.
    We will be happy to assist.
    -A.J
  2. #86
    Member shas595's Avatar
    Dec 2009
    Dan
    Yes that is correct. When the battery goes you lose it all
    PM me if you need more info
    John
    Quote Originally Posted by Dancy View Post
    shas595 (John?)
    short question for you. On a hitachi Seiki Micon-16, Seicos-II, when the battery dies you loose slbus data and parameters. Is the ladder lost or does that happen because of other problems?
    Dan
  3. #87
    Member Dancy's Avatar
    Aug 2007
    Default Re: Hitachi Seiki Repair / Service / Support
    Quote Originally Posted by Hitachi-parts-usa View Post
    Hello Dan,
    If John can not help you. WE would be happy to assist it sounds like you need a reload on your seiki. Let us know if you need any information about your machine or parts as we have a vast inventory of parts available. cybermachinery@gmail.com.
    -A.J
    Thanks AJ;
    short question: is the ladder lost on battery failure?
    I have a doc from Hitachi that implies no.
    SV03-999-62-010 instructs how to swap the ROM chips
  4. #88
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by Desertrunner View Post
    Hi all,
    I have a Hitachi Seiki VM40 and I want to redo the electronics, so the plan is to replace X, Y & Z drive motors and drives and only keep the current spindle and spindle drive which are Fanuc, the motor is A06B-1003-B300 and the Control unit is A06B-6044-H103. I am not fused about being able to tap and cut threads so if someone could suggest a simpler spindle I would be happy to change. Sadly I don't have any circuit diagrams as I had someone else helping and they dropped off the edge of the world with my books.
    Plan is to use Centroid equipment were possible.
    Any help would be greatly appreciated.
    Tony
    It is better to change the AC servo spindle motors and drivers too, to get the best performance and best compatibility.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  5. #89
    Aug 2007
    Hello Dan,
    -A.J
    AJ...your email box is full
  6. #90
    Nov 2016
    China
    hello ,i lost my Hitachi Seiki TF-20 Powermate sram,i need you help! can someone send it to me? or i can pay for it , thanks!! my gmail :520xuyuanlin@gmail.com
  7. #91
    hi i have a problem on a vk45II machine with SEICOS lampda 10M. Error 699 Directory broken Can you help me?
  8. #92
    Dec 2009
    Quote Originally Posted by alfredosindona View Post
    Yes send me an PM and I will help you out
    John
  9. #93
  10. #94
    Dec 2009
    I sent you a message take a look
    John
  11. #95
    Mar 2009
    Hungary
    dear friends,
    i have hitachi seiki vm40 with seicos my3...
    after on:
    it cannot to booting because : motion rtc unready...alarm,
    the 5. led (akku) is dark !!
    i replaced the akku , but the alarm no changed
    can anybody write to me what is the problem ?
    i have no parameters ( if they lost…i think that)
    can anybody send the procedure to mend machine and
    can anybody send the parameters?
    regards, kiss
