Hitachi Seiki Repair / Service / Support - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 73 to 79 of 79
Thread: Hitachi Seiki Repair / Service / Support
  1. #73
    venki46023's Avatar
    Feb 2019
    Hi shas,
    can you help me by resolving issue with VS50, 18M Hitachi milling machine showing an alarm 2082 (D408.2) ATC TWIN ARM ORIGIN ERROR.
    It is great for me if you help me me in this to up the machine.
  2. #74
    Member shas595's Avatar
    Dec 2009
    Default Re: Hitachi Seiki Repair / Service / Support
    Hello
    send me a PM with your contact info so I walk you through the process
  3. #75
    Mar 2012
    Need to use Block Skip 2 for bar loader. Looks like is an option in this machine.
    Machine: HiCell 23B, Seicos LIII
  4. #76
    Dec 2009
    Sent you A PM, take a look
    John
    Quote Originally Posted by marcin75 View Post
  5. #77
    Default HITACHI SEIKI HiCell 23 II
    ???? ?????? HITACHI SEIKI HiCell 23 II ? ?????? job ??? ??????????
    ??? ??????? ????????? ??????? ? ?????? MDI
    ??? ????? perrosprom@gmail.com
  6. #78
    Mar 2010
    Hi all,
    I have a Hitachi Seiki VM40 and I want to redo the electronics, so the plan is to replace X, Y & Z drive motors and drives and only keep the current spindle and spindle drive which are Fanuc, the motor is A06B-1003-B300 and the Control unit is A06B-6044-H103. I am not fused about being able to tap and cut threads so if someone could suggest a simpler spindle I would be happy to change. Sadly I don't have any circuit diagrams as I had someone else helping and they dropped off the edge of the world with my books.
    Plan is to use Centroid equipment were possible.
    Any help would be greatly appreciated.
    Tony
  7. #79
    Nov 2012
    Poland
    Do You have separate driver for each motor ? Or there is 3 in 1 driver for all the Motors? We want to do same thing with vm50 but can't find any info about the Asus drive unit and if it wasn't bad enough its connected through spindle drive... If there are separate drivers and they are fanuc IT should be easy to obtain the info about signals and using something like cslab csmio get machine working with existing drivers and Motors. If I You try search on Google "vm40 Linux CNC ", there is a thread of the guy who got one fully retrofitted using Linux CNC and mesa cards. We are propably will go with new servomotors if we can' find drivers for fanucs installed in machine.
  8. #80
    Mar 2010
    Quote Originally Posted by Muciek View Post
    The guy that did the Linux is the guy that let me don't and has my books.
    Each axis has its own drive and a Sayno Denki motor, its only the spindle that is Fanuc. Give how cheap Servo motors have become its worth just replacing with something new unless I can get new drivers and new encoder fitted to the old motors
  9. #81
    Nov 2012
    Poland
    Pm John here he is very helpfull , should hook you up with books or some info.
  10. #82
    May 2003
    Does anyone know the parameter to turn on the M8 (mist) option and the macro option? It's for a Matsuura MC-510V with a Yasnac MX-3 control. A options parameter list would be great if possible.
