Hitachi Seiki Repair / Service / Support - Page 4
Page 4 of 9 FirstFirst 1234567 ... LastLast
Results 61 to 80 of 179
Thread: Hitachi Seiki Repair / Service / Support
  1. #61
    Nov 2012
    Poland
    Default Re: Hitachi Seiki Repair / Service / Support
    My Hitachi vm50 got Orange screen , machine was staying idle then suddenly black screen appeared and everything was shutdown. Is it something with graphic card ,or LCD ? Or its the NC Control that is down?
  2. #62
    lt151881721's Avatar
    Dec 2018
    Hello, I bought a Hitachi hg400, fanuc 16m+siecos 10M controlled machine.The parameters of the machine were lost in transit.I need the parameters of this machine.I hope you can help me. Thank you.My email is 151881721@qq.com
  3. #63
    Member shas595's Avatar
    Dec 2009
    Yes please send me a PM if you need help still -
    John
  4. #64
    HELLO JOHN
    I HAVE HITACHI SEIKI HS400-HS800 HAVE LOST ALL DATA. AFTER ENTERING ALL DATA WE GET
    CNC ALARM
    790: BRAM ERR.01 ( SYSTEM TABLE ERROR ) SYSTEM TABLE IS ERRONEOUS
    PMC ALARM
    2004: TOOL LENGTH OVERTRAVEL D400.4
    2277: APC ARM INVERTER UNIT ALARM D427.7
    PLEASE HELPL US TO MAKE OUR MACHINE HEALTHY
    VIKAS KUMAR
    VIKAS ENGINEERING INDIA- Hitachi Seiki Repair / Service / Support-img_20181219_125807-jpg9871129244
    Attached Thumbnails Attached Thumbnails Hitachi Seiki Repair / Service / Support-img_20181219_125807-jpg
  5. #65
    Quote Originally Posted by vikasengineerin View Post
    HELLO JOHN
    CNC ALARM
    PMC ALARM
    VIKAS KUMAR
    Hello all,
    I have solve all of my machine alarms. Now the machine is ready and reference manually. But now the problem is when I command for reference machine value and absolute value make difference and axis is not reach at it's reference position.
    Example of machine value is 359.120
    Then absolute value is 35.9120 after moving 35.9120 mm machine shows alarm axis in not at reference position
  6. #66
    Apr 2004
    Pa
    Lost helical milling on VM50 with Lambda 10. Recently reloaded all Parameters.
    Can't get helical milling up
  7. #67
    Dec 2009
    Did you check your Option parameters (9000 series)
  8. #68
    Apr 2004
    Pa
    Hello,
    I have a Hitachi Seiki VM50 with Lambda 10 control.
    Lost helical milling after battery change.
    We don't have 9000 parameter list.
    Need parameter for helical option.
    Thanks Much
  9. #69
    Apr 2004
    Pa
    Yes, 9000 parameters are loaded, but apparently not the helical option. I don't know which parameter or bit controls
    helical. Worked fine before losing parameters.
  10. #70
    Member L98FIERO's Avatar
    May 2003
    Keswick, Ontario
    I HAD a VM40 and the Seikos control was based on a Yasnac, it was mid 80s so maybe an MX-3, would the parameter list be the same on both controls? I'm looking for the parameter list for the MX-3 as I picked up an older machine and want to find out what options it has and what are available.
  11. #71
    Quote Originally Posted by shas595 View Post
    Wayne,
    just sent you an email.
    John
    Hi I have an i80 yasnac control ..I'm trying to comp pitch error in the x axis.. book reads parameter 6801..it has a value 20000 in there right now ..I have changed it to various different numbers ranging from 0 up to 50000 but it is not changing my pitch error,Am I in the wrong parameter? After each number change I restart the machine but no change..
    Thanks,Jeff
  12. #72
    Aug 2016
    Mexico
    contacto: antonio aries 94@hotmail.com
  13. #73
    Aug 2016
    Mexico
    [QUOTE = fantasy196; 2169101] hola
    necesito manual de maquina seiki vm40 mecanizado vertical
    Hola
    necesito máquina manual seiki vm40 mecanizado vertical [/ QUOTE]
    contact: antonio_aries_94@hotmail.com
  14. #74
    venki46023's Avatar
    Feb 2019
    Hi shas,
    can you help me by resolving issue with VS50, 18M Hitachi milling machine showing an alarm 2082 (D408.2) ATC TWIN ARM ORIGIN ERROR.
    It is great for me if you help me me in this to up the machine.
  15. #75
    Dec 2009
    Hello
    send me a PM with your contact info so I walk you through the process
  16. #76
    Mar 2012
    Need to use Block Skip 2 for bar loader. Looks like is an option in this machine.
    Machine: HiCell 23B, Seicos LIII
  17. #77
    Dec 2009
    Sent you A PM, take a look
    John
    Quote Originally Posted by marcin75 View Post
  18. #78
    Mar 2010
    Hi all,
    I have a Hitachi Seiki VM40 and I want to redo the electronics, so the plan is to replace X, Y & Z drive motors and drives and only keep the current spindle and spindle drive which are Fanuc, the motor is A06B-1003-B300 and the Control unit is A06B-6044-H103. I am not fused about being able to tap and cut threads so if someone could suggest a simpler spindle I would be happy to change. Sadly I don't have any circuit diagrams as I had someone else helping and they dropped off the edge of the world with my books.
    Plan is to use Centroid equipment were possible.
    Any help would be greatly appreciated.
    Tony
  19. #79
    Nov 2012
    Poland
    Do You have separate driver for each motor ? Or there is 3 in 1 driver for all the Motors? We want to do same thing with vm50 but can't find any info about the Asus drive unit and if it wasn't bad enough its connected through spindle drive... If there are separate drivers and they are fanuc IT should be easy to obtain the info about signals and using something like cslab csmio get machine working with existing drivers and Motors. If I You try search on Google "vm40 Linux CNC ", there is a thread of the guy who got one fully retrofitted using Linux CNC and mesa cards. We are propably will go with new servomotors if we can' find drivers for fanucs installed in machine.
  20. #80
    Mar 2010
    Quote Originally Posted by Muciek View Post
    The guy that did the Linux is the guy that let me don't and has my books.
    Each axis has its own drive and a Sayno Denki motor, its only the spindle that is Fanuc. Give how cheap Servo motors have become its worth just replacing with something new unless I can get new drivers and new encoder fitted to the old motors
