Hallo Juergen23,
I guess you have a 3D measuring probe (infrared or funk)...
Neutral points or PRESETSs – you should have a good read about them or go to trainings/ get an introduction from an experienced colleague.
I explain you a way how you can set them with manually keying... so first without a keying program.wink.gif
Over the manual handling/ hand wheel handling -> Softkey ‘touching function’ and then measure and align the first vice.
The reference points that are set are usually filed automatically in PRESET 0.
Now after the first vice/ work piece is completely measured, you open the Preset table ( soft key) and choose another Preset row over the arrow keys and press the soft key ‘save PRESET’- the value from Preset 0 are now saved in the chosen PRESET.
You continue this procedure for the other bench vices and save for each vice a different PRESET.
