TNC 2500 b Backup Parameters Issue - What is the program number
Results 1 to 2 of 2
Thread: TNC 2500 b Backup Parameters Issue - What is the program number
    Member oz_eight6's Avatar
    Aug 2020
    Default TNC 2500 b Backup Parameters Issue - What is the program number
    Long time lurker first time poster,
    I am trying to export the Machine Parameters using TNC Server. cant find parameter file program number under which the machine parameters
    are stored
    I have had a Bridgeport VMC 1000 -22 (circa 1994)
    My machine parameters are all present and the machine for the most part is running well, will post them up here once i can get them backed up
    i have gotten as far as
    Below is the instructions on how to do it but i cant seem to find the "program number"
    Press "MOD" until "Code Number" is displayed
    Enter "95148" in CODE NUMBER
    Press "ENT" to Activate MP mode
    Press "EXT" & the press "ENT" to prepare TNC for data output
    Enter the program number under which the machine parameters
    are stored
    Press "ENT" to Start data transfer
    When the data transfer is finished, the dialog EXTERNAL DATA OUTPUT
    is cleared.
    Pres "END" to exit MP mode
    attached is an extract from the manual
    Attached Thumbnails Attached Thumbnails TNC 2500 b Backup Parameters Issue - What is the program number-capture-jpg
    Aug 2020
    Default Re: TNC 2500 b Backup Parameters Issue - What is the program number
    FIXED
    hope this helps someone else with similar issues
    Made one very small adjustment to the instructions and got it to work,
    Press "NOENT" to create new file
    are stored
    is cleared.
