problem-Gross Positioning error c in z axis
Results 1 to 4 of 4
Thread: problem-Gross Positioning error c in z axis
    Jul 2014
    Default problem-Gross Positioning error c in z axis
    Hello.
    I'm a new bridgeport interact 2 users.
    When i power on machine.It starting and Referenced but after z axis move
    it stop and show error "gross position error c " and position on monitor not changed ,but z axis before stop , moves about 5 centimeter.
    I changed x and z axis servo but again machine error "gross position error c " after moving z axis.
    anybody can help me.
    Mar 2016
    Poland
    Default Re: problem-Gross Positioning error c in z axis
    What control system is it? (smells like heidenhain)
    Did U check the easuring elements connection (encoders)?
    Jul 2014
    tnc 151.Yes i change z and x servo encoder and again same error.
    Mar 2016
    Poland
    Did U replace encoders itself or with motors,
    This error may be caused by losening the encoders axis clutch from the screw.
    Letter C not necessary means Z axis.
