Heidenhain tnc360 TOS fvp30cnc
Results 1 to 2 of 2
Thread: Heidenhain tnc360 TOS fvp30cnc
    Default Heidenhain tnc360 TOS fvp30cnc
    Hi.
    A question.
    Got an TOS fpv30cnc, with tnc 360 controller. Witch have som issues with parameter and plc program lists.
    Is it posible for me to retrofitt this old machine with some cind of new hardwere.
    Thinking PC baced controller?
    Ben Are
    Sep 2012
    Default Re: Heidenhain tnc360 TOS fvp30cnc
    Anything is possible if you are prepared to spend the money. Have you reloaded the machine parameters to try and sort out the current problem?
    Regards Bob
    teokar's Avatar
    Jan 2021
    Hi ,
    I bought a Tos Fng 63 cnc machine with Heidenhain Tnc 360 controller.
    Machine parameters are set all to 0 . Im missing the complete parameters to download them in order machine to start working again. I cannot moove manualy . Im changing some parameters but the are not saved after shut down. Batery block seems to have power (5v) .
    Is there a chance somehow to find a solution with this complecate situation?
    Thank you
