- TNC426 3D ROT (3+2 Elgamill retrofit) - German Controller (Copy from DE forum)
Our company has recently purchase an retrofitted Elgamill with a TNC 426 controller. They unable to assist further with using the 3+2 head rotation within the controller.
From my understanding we either use plane rotation or a cycle 19, however none of the A/B/C positions are listed on the screen.
We're also unable to locate the '3D Rot' soft key, and being all in german we are unable to see if the manual screen has any settings to enable it (pictures attached).
Would this be an issue of just enabling 3D rot, or are there 75xx parameters & rotation kinematics that should be calculated and set?
Looking for your $0.02.
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
