- TNC 355 B - PLC program
Hello All,
Can anyone share the PLC program and PLC parameters for a Kasuga Milling Machine RC-850?
Thank you in advance.
Bertrand
Re: TNC 355 B - PLC program
I used to write the PLC programs for these machines for the importer in melbourne. If you can send me some contact details i should be able to help you either with the original PLC program or an alternative one. Where are you located?
Hello All,
Can anyone share the PLC program and PLC parameters for a SWH UF41 HDH TNC355b 1991year of construction?
Vladimir
Hi there, I have a similar problem, lost the PLC program after the 24v power supply failed. batteries had low voltage and didnt save it. Its a kasuga TC-100 with heidenhain TNC415b controller, has tool changer, was originally sold to Trico by Internation Machine Tools. IMT.
in the early 90's. Any help is welcome. contact me at kevin@grating.com.au . Cheers,
- You may not post replies
- You may not edit your posts
Forum Rules
