TNC 426 language change parameter
Results 1 to 2 of 2
Thread: TNC 426 language change parameter
    Feb 2016
    Lithuania
    Default TNC 426 language change parameter
    Hello,
    I got milling machine with heidenhain tnc 426 control system. I dont familiar with this system so i have two problems. First of all i would like to know how to change language from german to english. Second how to fix this problem which you can see in attachment. Thank you.
    Attached Thumbnails Attached Thumbnails TNC 426 language change parameter-1111-jpg
    Mar 2016
    Poland
    Default Re: TNC 426 language change parameter
    The parameter is 7230 (point 1, 2, 3 and 4)
    set it to 0 for english.
    upper message means button with no function (u can remove it with CE- it should have no effect for work with machine)
    Lower message is not familiar for me at all...
