good morning!
I am new with heidenhain control, I am trying to cut a small pocket at X-1.7 from center part @-45 degree from B axis. I don't know why when I use cycle 7 and cycle 19 to rotate and shift the datum, the machine did not read the right offset in X and Z axis. I have checked in parameter #7500 :%0001. I don't know what happened to the machine or something wrong with my program. my machine is Parpas Sl 90/3500
Heidenhain TNC 426 CB. this is my simple program:
0 BEGIN PGM 19 INCH
1 BLK FORM 0.1 Z X-5 Y-5 Z-3
2 BLK FORM 0.2 X+5 Y+5 Z+0
3 TOOL CALL 0 Z S2500
4 CYCL DEF 321 C AXIS VERT.POS.ING.
5 CALL LBL 1
7 L B-45 R0 F MAX
8 CYCL DEF 7.0 DATUM SHIFT
9 CYCL DEF 7.1 X-1.7
10 CYCL DEF 7.2 Y+0
11 CYCL DEF 7.3 Z+0
12 L Z+10 X+0 Y+0 R0 F MAX
13 CYCL DEF 19.0 WORKING PLANE
14 CYCL DEF 19.1 B-45 F2500
15 L X+0 Y+0 Z+10 R0 F MAX
16 CYCL DEF 5.0 CIRCULAR POCKET
17 CYCL DEF 5.1 SET UP 0.1
18 CYCL DEF 5.2 DEPTH -0.25
19 CYCL DEF 5.3 PLNGNG 0.035 F200
20 CYCL DEF 5.4 RADIUS 0.4
21 CYCL DEF 5.5 F500 DR+
22 L M3
23 L X+0 Z+0.1 F MAX M99
24 L Z+10 R0 F MAX
25 CALL LBL 1
26 LBL 1
27 CYCL DEF 19.0 WORKING PLANE
28 CYCL DEF 19.1 B+0 F2500
29 CYCL DEF 19.0 WORKING PLANE
30 CYCL DEF 19.1
31 CYCL DEF 7.0 DATUM SHIFT
32 CYCL DEF 7.1 X+0
33 CYCL DEF 7.2 Y+0
34 CYCL DEF 7.3 Z+0
35 CYCL DEF 7.4 B+0
36 LBL 0
37 L Z+10 R0 F MAX
38 L B+0 R0 F MAX M30
39 END PGM 19 INCH
?someone please help me!
thank you
Attachment 348607problem about cycle 19 and cycle 7, machine caculated wrong offset x and z-2-jpgproblem about cycle 19 and cycle 7, machine caculated wrong offset x and z-2-jpg
