- HEIDENHAIN Webinar - Adaptive Feed Control (AFC)
Hello,
this webinar will describe how to customize and use the Adaptive Feed Control (AFC) software option. AFC automatically regulates the feed rate of the TNC, taking into consideration the respective spindle power and other process data. In a teach-in cut, the TNC records the maximum spindle power. AFC provides the following benefits: Optimizing the machining time, Tool monitoring, Protection of the machine mechanics.
Start 2017-01-19 14:00
Request participation
https://en.industryarena.com/heidenh...ar/1373899129#
Best regards
Michael Wiendl
- You may not post replies
- You may not edit your posts
Forum Rules
