- data transfer between TNC355 and a computer
Hello
I have the following problem:
Machine Mirkron WF71
Controller TNC355
Computer Windows XP
I cannot establish a connection with TNCremo. The problem is probably the transmission protocol- that’s how far I got with the help of the forum.
So now with the TNCServer
However when I open the TNC server then I can send from the machine to the computer.
However when I want to get the programs from the computer then it comes to a break off!
Does anybody have an idea?
Greetings
Benotto
Are the Baud rate and the connection type of the computer and the controller equal? If yes, then go down with the Baud rate and make you way upwards.
Thank you dir1
I already played with the Baud rate, now I have set the standard value 9600 again.
I have also played with the connection type FE and ME, also only send ME and receive ME
I just don’t know why it continuously breaks off.
Can I send the program from the TNC Server?
Usually that doesn’t work- but another question: when does the transfer breaks off?
Maybe our memory is not sufficient for the program?
I know it from my machine; usually after 5000 signs it’s full
Hello Benotto!
Have a look into the user parameter of the controller if the data transmission EXT is configured.
You have to use baud rate 2400 with that old controller- and it’s best to use ME send/receive.
Or maybe the memory is full. You can only save max. 20 programs or 3000 blocks.
However the TNC should release an error message (NC memory)
Kind regards
The memory is pretty full!
I have deleted 2 programs that I have saved on the computer and now I tried to send one of them from the computer.
The result was that it started to send and then after 3 rows the TNC server wrote “break off”. Maybe I am doing something wrong on the machine?!
I go to receive selected program and then enter the program number that I would like have.
Hello Benotto
Of course, the program name has to be identical with the name behind “Begin PGM...”
Kind regards
I think I got it right; I have named the program 12345. The file is called 12345.h and then I enter 12345
How long is the cable between the TNC and the computer? It should not be longer than 8m.
Kind regards
You can also try to use a different interface with the TNC server (COM-Port) but if you are able to receive then it’s pretty unlikely. But sending definitely works with the TNC server.
Kind regards
Hello
I had the same problem a few years ago.
Have a look at my description to see if the MP222 it set to 168.
Regards
Lars
Heidenhain TNC 155 or rather 355
Transfer end to ETX
Row end = ASCII 13+10
Protocol to XON
With TNC135 : 100x ASCII=0 as credits, and recognise read-in end with 5 seconds idling.
From TNC155 : In case the machine doesn’t read-in set parameter 222 = 168
In PDF section 5.1.2 as described = 7 Datenbit, 1 Stopbit, even Parity, Software-Handshake
Set operation mode = Over MOD or Machine parameter -> EXT-Mode
Standardformat, no block by block transmission - Parameter 223 = 0 or rather from 5000
CPVwin can no FE , ME , LSV/2 Protocol or block by block transmission
transmission end EOT : Parameter 224 = 4
Hi
I do it like this:
Heckert: Pc to TNC
1.Start TNC-Remo, 2. In configuration: select "ME Send".
3.Enter program file.
4.Then go to the machine and press “EXT" and also read-in selected program” and press Enter. Enter the program number.
TNC to PC
1.start TNC-Remo, 2. In configuration: select "ME Send".
3. Enter program file and press save.
4. Then go to the machine, press "EXT" and “release selected program”
and Enter. Enter choose program.
The program is visible on the computer after pressing F5 (refres)
Remo basic settings
Baud rate : 9600 / interface : Com 1 / controller type : TNC355
FE-settings
Tick the both of the upper fields
Folder
No ticks
In main window at the right side
Protocol : LSV-2 / interface : Com 1 /Baud rate(Auto Detect) : 9600
I have a Heckert with TNC 355
Program file has to be .H (big).
Try it out
Kind regards
Cleaner
Hello everybody,
I am new here and I need your help. Could anybody tell me how can I export the data from a ND 280 into notepad or excel please? I tried once but I've got only one .txt file storing just the last measured value. How can I export every point I have measured please? I really need to know how to do this...
Thank you and I hope you can help me
Regards,
Vlad
Hello everybody,
Regards,
Vlad
- You may not post replies
- You may not edit your posts
Forum Rules
