- Can't Delete Programs
I can't find a way to delete programs in heidenhain millplus v320. The instruction manual just tells to go to program tab then press menu and select remove program. But I when I go to the menu I don't have that option the menu looks different there is only the possibility to choose a program.
Attached are photos of the manual and what my menu looks like.
Re: Can't Delete Programs
Use the control tab / menu for file options.
yes.
control tab -> Menu -> file editor
In File directory , programs list will be displayed
you will have delete soft key in the screen.
- You may not post replies
- You may not edit your posts
Forum Rules
