- engraving cycle
I am currently writing an engraving cycle with different character encodings. I don’t want to write one programming row per character as normal. I want to create a character string in a String-parameter (ES)... The String parameter should then be read out character by character (from V600-03 SP13) and then written (engrave).
So now my problem:
How can get the inverted commas into the string parameter or rather can I continue processing that character?
Please no external solutions like CAM or anything like that, if possible only Millplus!!
Regards
With the Heidenhain-iTNC 530 I solved it roughly like that:
"In %34inverted comma%34" engraved: In "inverted comma ".
If the %- character is used in the string, then the following 3 numbers are seen as character numbers.
That way also the characters that cannot be entered in the string parameter can be engraved.
Regards
cgTNC
- engraving cycle
- You may not post replies
- You may not edit your posts
Forum Rules
