Hello Hunterkoile
The maximum number of files is determined by a machine constant. I would not advice you to change that constant because then all the tables (zero points, tools, etc.) will be deleted as well as the position of the axes that are not usually run towards a reference point ....
The best solution is to create subfolders and to distributed the files so that the maximum number of each folders is not exceeded.
Greeting cheese
