MILLPLUS V400 gateway disconnected
Results 1 to 3 of 3
Thread: MILLPLUS V400 gateway disconnected
    Registered CADBAER's Avatar
    Jan 2011
    Halstenbek
    I urgently need your help.
    We bought a 10-year-old DMU80T with controller MILLPLUS V400.
    When we try to start it up, the error I01 (gateway disconnected) occurs.
    Turning on with the Clear button and the main switch remains ineffective.
    What gateway is meant? How can the problem be solved?
    I’d appreciate your help.
    I’ll also post the solutions
    narator's Avatar
    Dec 2007
    Bayern
    Hello
    Is the emergency switch in its initial position?
    Then, do you press the switch button first and immediately after that the CE-button?
    You have seen the machine in action, haven’t you?
    Greetings
    steff_ndb's Avatar
    Dec 2007
    Bayern
    Hello
    Exactly, first you should check up, whether the emergency switch is out, also at the hand wheel! I’ve once searched for it until I was blue in the face cause I hardly ever use it.
    Then, I had to open and close the door in order to lock up the door switch!
    And then press the main switch and F10 at the same time. It should work then.
    Regards, Steff
