- feed changing
Hello at all,
I've got the following question.
Normally we programm via machined part ever.
I mean: describe the contour at ''machined part'' and than process the contour at ''machining'' with G890 cycle.
Is it possible to turning another feed for a face as specified at ''machining''?
Greetings
You can programm at your machined part a special feed factor for a face. The command is G38.
Factor 0.5 means: when the machine's got a feed of 0,1 - this value is cutted into halves at the programmed face.
Greetigs, Eternal Fire
- feed changing
- You may not post replies
- You may not edit your posts
Forum Rules
