- Network connection with manual turn
How does it work?
According to the machine manufacturer, it won’t work until a newer software update. But we could access the menu for network settings for TCP/IP so it has to be unlocked.
Is there a manual therefore and do we have to connect a keyboard therefore?
I don’t know what software update our machine has. But I’m sure that I had to connect a keyboard for configuration.
It was quite easy in our case. I just had to unscrew the screws that held the monitor (industry PC) and so I could access the connectors.
Good luck
Volker
- You may not post replies
- You may not edit your posts
Forum Rules
