- Chamfer with iTC530 system
Hello
thank you for entering in my post
I have a piece of alluminion with a square section 72mm x 72mm and 400mm long I need to bring it to 392mm (finished dimension)
So I need to work only both the ends, in addition I need to make 4 chamfers 5mm x 45° on the corners
What kind of function whould you use to make the chamfers ?
1) normal linear movement
2) polar coordinates
3) CHF function
I know that probably CHF function is the best way to do it but for some reason with my iTNC530 doesn't work
However whatever function would you use to do it, it should work but my iTNC530 shows always a different grafic even in full sequence mode
any suggestion accordin this matter will be very appreciative
thank you in adavnce for your help
Hello
3) CHF function
- You may not post replies
- You may not edit your posts
Forum Rules
