programming station demo as on machine
Results 1 to 5 of 5
Thread: programming station demo as on machine
    dodo3's Avatar
    Jul 2003
    Hello
    It’s is possible to set up the programming station like it is on a machine?
    I mean the whole kinematics and the soft keys.
    I have the backup of the machine.
    Unfortunately the machine manufacturer don’t like to give it out as it is on the training courses
    Kind regards
    Dodo
    cgTNC's Avatar
    Nov 2010
    Braunschweig
    Is the backup only from the TNC folder or of the PLC?
    In the PLC you can find a folder which is called kinematics or a similar name...
    You have to play it in with the TNC Remo in the demo version.
    Also adjust the OEM.SYS in the row KINEMATICS according to the backup.
    Regards
    cgTNC
    Administrator CNCFanatiker's Avatar
    Dec 2001
    EE-Kreis / Germany
    Hello
    Hello dodo3
    What’s included in your backup? As cgTNC already wrote, you need more than just a back up of the system files. An update of the complete PLC would be optimal
    However an interesting topic, what about we create a little tutorial to adjust the programming station.
    Let’s see where we reach out limits
    Let’s make a check list of the points that need to be considered when adjusting the work station.
    We will need:
    1. Adjust depending on the software version (identical software version on PC and on machine)
    2. original PLC update of the source- machine
    3. please add
    What needs to be modified:
    1. Kinematics
    2. M-commands ( possible manufacture specific)
    3. MP adjustments and user parameters
    4. user macros
    5. please add
    Gruß / Regards
    CNCFanatiker
    AdminCrew
    Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.
    If we always this act what we are able to do, then we always remain what we are.
    schwindl's Avatar
    Sep 2008
    Traunwalchen
    Cycles, that will be tricky without cycle design
    Travel areas
    Tool.t
    Gruß<br /><!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto-->Schwindl<!--fontc--></span><!--/fontc-->
    dodo3's Avatar
    Jul 2003
    That sounds very good already.
    The backup is 175MB and it can be opened with TNCremo.
    In there are 2064 files.
    Kind regards Dodo3
