Q Parameter Programming - Error Check
Results 1 to 2 of 2
Thread: Q Parameter Programming - Error Check
    Matt_Delta's Avatar
    Feb 2018
    5YE
    Default Q Parameter Programming - Error Check
    Hi
    Can anyone help me with the following issue.
    I have a number of new trainees that are doing basic setting up and operating milling machine.
    We have had a couple instances where a trainee has machined the bed by not setting Z correctly.
    I would like to come up with some coding to stop this from happening but not sure where to start.
    I assume you can pull data for the tool length from the tool table and then take the actual machine co-ordinates to specify bed location.
    Controller - iTNC530
    If anyone can help it would be really appreciated.
    Thank you
    Matt
    Dec 2011
    Hungary
    Default Re: Q Parameter Programming - Error Check
    Data transfer NC > NC program (FN18: SYSREAD)
    The FN18: SYSREAD function is particularly useful for OEM cycles if you wish to have access from the NC program to certain NC data, such as active tool compensation. A group number, a system data number, and an index specify the particular item of system data that you read:
    FN18: SYSREAD Qxxx = IDxxxx NRxxxx IDXxxxx (xxxx: Q parameter or numerical value)
    Examples:
    FN18: SYSREAD Q1 = ID50 NR1 IDX4
    Q1 = T4 Tool length L
    Q1 = Current Tool length L
