- iTNC530 QR Values
iTNC530 QR Values
I use Q values a good bit for my programming routines, however if the machine is powered down I loose the Q values and have to reload them.
I was reading the manual and seen that QR values are supposed to be non-volatile in a machine shut down situation.
I take it this means, that if I use QR values instead of regular Q values that this will fix the issues.
How do you view the QR values to see what they are set to?
Thanks in advanced.
Re: iTNC530 QR Values
Press Q button on single/auto side like you normally view Q-parameters and press the "Q,QL,QS,QR" soft key to toggle the list
E: didn't notice this topic was three years old, sry
- iTNC530 QR Values
- You may not post replies
- You may not edit your posts
Forum Rules
