machine is crazy
Results 1 to 5 of 5
Thread: machine is crazy
    Registered Dyscha's Avatar
    Mar 2012
    Kleinstadt
    Hey
    My machine is crazy at the moment. When I get the chamfer countersink out to mill the drill holes with it, the machine suddenly stops and the program breaks off.
    The note “external Emergency Stop” or the speed decreases from 6000 to 2000.
    What could be the reason for this?
    Registered bullet01's Avatar
    May 2009
    Buchstehude
    Hello
    These details are not enough- what machine, controller have you got?
    Does it happen with every single program or only particular ones?
    Are there any other (more exact) error messages?
    Mar 2012
    Kleinstadt
    Machine: Mikron VCP 1000
    Controller: Heidenhain TNC 430
    The program is generalized and usually runs without problems. Only with the chamfer countersink these problems occur. The error messages are various. Sometimes the protection door is open or external emergency stop comes up or even no error message- then the engine speed just decreases. I often have problems to close the door, the machine always shows the error “protection door component part”.
    GreenVeltlins77's Avatar
    Jun 2005
    How large is your "chamfer countersink"?
    Maybe it has too much power.
    Regards
    Sven
    CNCMarci's Avatar
    Jan 2012
    L?denscheid
    I don’t think that it’s because of the size.
    Maybe the door protection switch has a loose connection in the cable or maybe it doesn’t close properly anymore.
machine is crazy
machine is crazy
machine is crazy
