Nowadays CF cards are built into the control cabinet of the controller. It looks like a brass case that can be flipped open.. The network cable etc. go into it as well....
Hello guys
The hard disk of our machine is already 15 years old and it probably has some errors already. Therefore we would like to exchange it ....
Where exactly is the HDD build in? Do I have to unscrew the cover where the monitor is or does it go somewhere else?
-is it a normal IDE HDD?
Can any problems occur if I build in a disk with a higher capacity or rather can the machine cope with a bigger disk?
Regards
Manuel
<b><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->Gruß General<!--sizec--></span><!--/sizec--></b><br /><br /><br /><br /><!--sizeo:3--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><b>Fräser sind Halbgötter in Blau.<br />Denn sie lassen durch Zerstörung Neues entstehen!!!!</b><!--sizec--></span><!--/sizec--><br /><br /><br /><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><u>Werbung in eigener Sache:</u><!--sizec--></span><!--/sizec--><br /><i><!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->Enter the Matrix an feel the Moment "<u>www.pixxelmatrix.de</u>"<!--sizec--></span><!--/sizec--></i>
