Destruction of solid state relays
Results 1 to 2 of 2
Thread: Destruction of solid state relays
    vinnygalbo's Avatar
    Sep 2018
    Default Destruction of solid state relays
    My luck sucks with solid state relays. And since I am not a great believer in luck, I'm thinking I do something that kills them. I can't imagine what though.
    My streak of bad luck started with releco relays like this one.
    https://www.clrwtr.com/Products/CSS-N13X-DC5-48V
    we were using 48V versions. Originally these were the type that switched with 120V, but later we used the kind switched with 24V.
    We also had issue with high amp relays from omega that also switched 120V AC from a 24VDC coil.
    http://www.omega.com/pptst/SSRL2
    Since the failure rate is high, we are planning to switch again.
    So: What can cause solid state relays to fail? and way more importantly, what inexpensive way is there to detect and subdue a failure, because each and every failure was a closed circuit! So heaters go ON when a relay fails. That is bad news!
    *Registered User* amiloosingit's Avatar
    Nov 2018
    I'n pretty sure you should use some damn good oil while frictioning to prevent it from overheating. I mean, not some cooking oil like https://kaissaoil.com/en/factory-of-...-and-refining/ but engineering oil. And you'll be good. No doubts.
