Harrison Alpha 400 software issues
Results 1 to 9 of 9
Thread: Harrison Alpha 400 software issues
    Apr 2018
    Netherlands
    Default Harrison Alpha 400 software issues
    Hey everyone,
    I have some questions about the Harrison Alpha 400 lathe and the software.
    Since we have the lathe we have never used the Alpha Link software. Now after a lot of years i took the task on me to get the cam package working but I've encountered some problems.
    I'm using Windows 7 on the desktop and the Alpha Link software is a DOS vintage package. Because win7 no longer supports programs that old i tried using Virtual Machines running DOS / Win 3.1 / Win 98 and it had been a pain in the butt to even get the programs to boot.
    I read here that there is an updated version of the software? Does Alpha Win work on windows 7 and if so, is there anywhere i can get the Disk or even an ISO.
    or is there an even newer version that works?
    The Alpha 400 lathe is build in 1998.
    Any help is much appreciated.
    Kind regards,
    Michael
    Feb 2018
    United Kingdom
    Default Re: Harrison Alpha 400 software issues
    Hi Michael,
    AlphaWin does run on Windows 7 but I think Superdraft use One CNC to support the alpha 400/500 range now.
    Apr 2018
    Netherlands
    Thanks for the info! I'll look into it.
    If more questions come up i'll ask it here
    May 2016
    United Kingdom
    You will have to check the version of software on the Alpha as this defines whether the windows version works, it will only work on version 3 Alphas
    Easy way what is the version of Dos software you are using it is written on the front
    Apr 2018
    Netherlands
    We have Alpha link version 3.1. I saw on the Superdraft website that for 160 pounds we can buy the windows upgrade for this version.
    May 2016
    United Kingdom
    Yes that is correct the upgrade started at version 3.1
    Happy programming it is easier to use and all existing drawings and programs will transfer any problems please pm me
  7. #7
    Exclamation Re: Harrison Alpha 400 software issues
    This is a long shot, but anyone able to assist me with a copy of the Alphalink software, or advise what software I can use to operate an Alpha 400 as well as an Alpha 460 with Fanuc controls?
    Thank you.
  8. #8
    May 2016
    United Kingdom
    Messaged you back
  9. #9
    Feb 2018
    United Kingdom
    Quote Originally Posted by BlueDemonCo View Post
    Thank you.
    I’ve got a copy that might help, what age is your machine ?
