Pics of setup? Sounds like you need less rake on your cutter, Al Bronze is "grabby" stuff
I am struggling to put a 6mm external ball groove in some aluminium bronze, not sure what grade it is but I could find out. Running at about 500RPM, feed 0.06mm, no pecking just feed in and rapid out. Just ran one before and it chattered like crazy, the tip broke then the billet near enough came out!
Any help will be much appreciated.. Unsure if it will make any odds but I am using a Harrison alpha 400.
- Ball Bearing Supplier, Deep groove ball bearings, small ball bearings, steel ball bea
- How much axial force a deep groove ball bearing can take?
- gibs from oilite bronze sintered bearing material instead of brass/bronze
- How to select shaft tolerence for preload of deep groove ball bearings?
- V-groove bearings and aluminium angle
If at first you don't succede destroy all evidence that you tried!
