- alpha 550+
alpha 550+
I'm having problems threading on our alpha lathe. It has the fanuc control without g code. It will go to thread and jus sit in position. It jerks like its going to start but stops. Also does it threading using cam file. Any thoughts? Already replaced encoder and no luck tthere.
- alpha 550+
- You may not post replies
- You may not edit your posts
Forum Rules
