CHNC 1 loose turret plate
Results 1 to 3 of 3
Thread: CHNC 1 loose turret plate
    May 2012
    Us
    Default CHNC 1 loose turret plate
    I recently changed my top plate on my chnc 1 and now there is about 1/4" of play in it. The bolts are all tight and it indexes fine but with minimal pressure it will turn about a 1/4". Is there an adjustment for this?
    Member Karl_T's Avatar
    Mar 2004
    Dassel.MN
    Default Re: CHNC 1 loose turret plate
    Your stop pin is not coming in. First guess would be dirt and swarf in the pin or air cylinder.
    May 2012
    Us
    Thanks for the reply. Does the pin engage the top plate directly or does it engage the piston that rises and turns which the top plate is bolted to? Trying to figure out if I could have gotten some dirt in there when I changed the top plate.
