Build Thread Yet another Hardinge Accuslide
Results 1 to 4 of 4
Thread: Yet another Hardinge Accuslide
    Jan 2012
    Default Yet another Hardinge Accuslide
    I recently picked up a Hardinge AHC that's been fitted with an Accuslide. The parameters were lost when the batteries died, the spindle encoder is bad and the VFD is DOA. Good candidate for a retrofit 8-) .
    These pictures are at the shop where I got it. My quarters are too cramped to get a good full on shot. Some parts have already showed up so hopefully progress will be quick.
    Got the acorn up and ran through the initial setup. Also the motors/drives and did the initial tune on them also.
    Attached Thumbnails Attached Thumbnails Yet another Hardinge Accuslide-118410146_10223936124935699_8909415589281684242_o-jpg   Yet another Hardinge Accuslide-118470992_10223936123295658_4054909559704013473_o-jpg   Yet another Hardinge Accuslide-118581125_10223936123575665_8309720820276694305_o-jpg   Yet another Hardinge Accuslide-118380845_10223936124895698_7263096148510119702_o-jpg
    Yet another Hardinge Accuslide-118470992_10223936121655617_3846109422081069655_o-jpg   Yet another Hardinge Accuslide-118326669_10223936123815671_9075096952726316434_o-jpg   Yet another Hardinge Accuslide-20201125_111228-jpg   Yet another Hardinge Accuslide-20201125_111232-jpg
    Jan 2012
    Default Re: Yet another Hardinge Accuslide
    I got the computer mount moved back to give me a little more room to move around.
    The box is cleaned out.
    New face plate made and mounted. There will be another over this one for the monitor. I plan to mount the drives to the back of this plate.
    Yet another Hardinge Accuslide-20201126_090802-jpg
    Yet another Hardinge Accuslide-20201126_090825-jpg
    Yet another Hardinge Accuslide-20201126_095754-jpg
    Jan 2012
    Little more progress yesterday.
    Drives mounted
    Monitor mounted to faceplate and then mounted to the box
    Made a small bracket to hold the computer and USB ports - trying not to penetrate the outer shell if I can avoid it.
    Yet another Hardinge Accuslide-20201126_095811-jpg
    Yet another Hardinge Accuslide-20201126_110615-jpg
    Yet another Hardinge Accuslide-20201126_115710-jpg
    Jan 2012
    Got a little more done in both cabinets. Still need to do some wire management but lights are coming on and flashy things are flashing!
    Yet another Hardinge Accuslide-20201204_134042-jpg
    Yet another Hardinge Accuslide-20201204_134051-jpg
    Yet another Hardinge Accuslide-20201204_134121-jpg
