- Need Help!- Hardinge GT27 Fanuc 18t Control lube problem
We have a problem with the slide lubrication Autolube system.
It alarms out in the mornings every 2.5 mins for a couple of houres then works ok.
we check the pressure switch and thats ok, replaced the original lubricator with a chineese one which is set to cycle every 2mins for 10 seconds.
still having the 1016 alarm with new auto lubricater. checked all pipes for leaks and all are ok.
Eventualy after 2 or more houres the MC will run without a problem rest of the day, untill the next morning when we have the same problem.
looking to disable the timers keeprl or whatever controls the frequency and time of lubricator, its not needed now we have the chineese lubricator.
What parameters do we alter?
Mike
- You may not post replies
- You may not edit your posts
Forum Rules
