....If, possible Backup any parameters, programs, etc before replacing battery. Quick search found this thread about 810T machine...
https://www.cnczone.com/forums/hardi...448-posts.html
hello everyone I bought a hardinge chnc1 lathe about a month ago
finally powered it up the other day on the screen it says battery alarm power
i assume i need to change the battery can anyone tell me exactly where it
is located it has siemens controlls
there could be a coin style battery on the memory board along with the 3.6 volt battery that you access from the back side where the crt is
if the control got a memory board upgrade then it only uses the 3.6 volt battery
you replace the battery while the power is on
getting a back up of the parameters is a good idea before replacing the battery
machineshop5 gave you a very good link with pictures of the battery's and information
If you have a Siemens control, it is under the panel that covers the back of the control. Be sure to have the power on before removing the battery cartridge. If that does not fix your problem, there is a battery on one of the boards too. But don't pull boards if you do not need to.
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
