Need Help! First time getting a Cobra 42 to run, spindle does not run
Results 1 to 7 of 7
Thread: First time getting a Cobra 42 to run, spindle does not run
    Jan 2006
    Default First time getting a Cobra 42 to run, spindle does not run
    I have a new to me Cobra 42 that is in very nice condition. I have it powered and starting to work with it.
    The main issue right now is that the spindle does not run when I step through a very basic program. And it does not when in MDI mode either. While running in single block mode the program goes through each step flashing the Cycle Start button light at each block as I push the button for the next block. When it gets to the block for turning on the spindle the button light stays on, the program does not advance, and the spindle does not turn on. No messages nor alarms are displayed. It sits in that mode until I hit the reset key.
    Any ideas?
    The machine was running until the day I picked it up. I have not found anything in the manuals that would lead me in any direction.
    Thanks,
    Kevin
    Member machinehop5's Avatar
    Aug 2009
    Default Re: First time getting a Cobra 42 to run, spindle does not run
    Power Down,,,turn off Main Power ..wait for 20 mins to be safe (Cap's Discharge)..start checking Fuses to Spindle drive to start with. Get some photos of the drive may help too. are any LEDs lighting up on drive?. Model # of Drive may help us. Do you have any machine Manuals?
    Jan 2006
    I have attached a couple pictures of the screen and of the controller when in the "stuck" situation. The first picture is of a sample program I am trying to step through. The second is the step where it gets "stuck" trying to control the spindle. And the last picture is of the controller during that step.
    Did I miss something in the controller software? Or is this a hardware issue?
    First time getting a Cobra 42 to run, spindle does not run-new_105-jpg
    First time getting a Cobra 42 to run, spindle does not run-new_115-jpg
    First time getting a Cobra 42 to run, spindle does not run-new_110-jpg
    Dec 2013
    Your pictures are not viewable.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2006
    Quote Originally Posted by Jim Dawson View Post
    Hopefully I fixed that.
    Thanks.
    Dec 2013
    You might replace your M13 with a M3.
    Jim Dawson
    Sandy, Oregon, USA
  7. #7
    Jan 2006
    Thanks but I already tried that. Along with M4 and M14. They all did the exact same thing, nothing.
