Need Help! Hardinge CHNC 1 emergecy stop 6000
Results 1 to 16 of 16
Thread: Hardinge CHNC 1 emergecy stop 6000
    Member moonman5's Avatar
    Aug 2012
    UK
    Default Hardinge CHNC 1 emergecy stop 6000
    Hi All,
    Subject to my previous post on my Hardinge CNHC1 Siemens 810T control, So now I have managed to get the machine to power up (the fault was a short in the turret encoder) It took
    me an age to find! I have removed the faulty unit, looks like its sealed in some sort of resin?
    I now have a 6000 Emergency Stop, my question is will the machine give me this E-stop even though I have removed the faulty unit (I thought I might still be able to move the axis and maybe
    start the spindle? as I do not get any alarms related to the turret?
    Thanks for any help.
    Allen
    Member Machineit's Avatar
    Mar 2010
    Default re: Hardinge CHNC 1 emergecy stop 6000
    Make sure BOTH of the emergency stops are off, then clear the alarms. You can do nothing until that alarm is cleared. I had a bad E-stop switch on mine once.
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Aug 2012
    UK
    Thanks for your reply greatly appreciated, Yes I have done that, I have also checked both e-stops with a digital meter and both are good, The machine is not on the hard stops (I always move the axis
    well clear of the limit switches before I shut the machine down,
    Is it possible with the turret encoder removed that this would cause the e-stop? (6000)
    Thanks Allen.
    Mar 2010
    Nope, looks like just the e-stop switch.
    See attached
    Attached Files Attached Files
    Nov 2011
    I have a spare E stop switch if needed ! ed.murch@mamcomolding.com
    Ed
    Mar 2010
    That's good, hope you find the problem. Hard to help you from long distance!
  7. #7
    Aug 2012
    UK
    Thanks for the attachment, a great help! So you don't think that with the turret encoder completely removed it will give me an E-stop? that was my thoughts? do you think it could be a faulty limit switch?
    I have been trying all day to clear the alarm but no luck
    Thanks again for your help
    Allen.
  8. #8
    Aug 2012
    UK
    Hi Ed,
    what about a Turret encoder?
    Thanks,
    Allen
  9. #9
    Nov 2011
    Allen,
    What # is on yours ? C2-137B Can't read the number on the other one
    ed
  10. #10
    Aug 2012
    UK
    Hi Ed,
    Yes! that's exactly the same number, C2-137B Have you got one?
    Allen.
  11. #11
    Nov 2011
    Allen,
    Yes i do !!!!! Make me a fair offer . Is there anything else you need ? Give me an address to send ! Can you pay by paypal ? If so i can send you an invoice .
    Ed
  12. #12
    Aug 2012
    UK
    Hi Ed,
    Yes I can pay via PayPal, I don't no where to start with an offer, got no idea what they cost new (not that you can get them now) I am in the Uk so obviously there will be postage costs
    Can you give me a price or somewhere to start?
    Allen
  13. #13
    Nov 2011
    Allen,
    company owner said $150 with shipping and i well give you a e stop ! How does that sound ?
    Ed
  14. #14
    Aug 2012
    UK
    Hi Ed,
    Yes that sounds ok to me, can you just confirm that the part is in good working order, and also I will need your e-mail address to send money via PayPal,
    Thank you,
    Allen
  15. #15
    Nov 2011
    Allen,
    I myself removed it ! It was working fine when removed a month ago . ed.murch@mamcomolding.com is mine . alyssa.albert@mamcomolding.com send for payment and address to send parts
    thanks
    Ed
  16. #16
    Aug 2012
    UK
    Hi Ed,
    So you have given me two E-mails what one should I send money to? bit confused with your reply,
    Allen.
