Drip Feed / DNC? --- Conquest T42 with Fanuc 18T controller
Results 1 to 3 of 3
Thread: Drip Feed / DNC? --- Conquest T42 with Fanuc 18T controller
    Member shaggyd's Avatar
    Feb 2019
    Default Drip Feed / DNC? --- Conquest T42 with Fanuc 18T controller
    I have a Hardinge Conquest T42 with Fanuc 18T controller. There is clearly no switch to put it into tape mode. Is there soft key for tape mode?
    I have the RS-232 hooked up to a Titan USB, which works great for moving files. I now have some programs that I can't get to run because they are too large.
    I thought I had seen "tape" somewhere on one of the control soft keys. I'm certain I have seen "punch" for outputting files. There must be a way to get this thing into tape mode. What's the scoop???
    Thanks!
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Drip Feed / DNC? --- Conquest T42 with Fanuc 18T controller
    https://www.easydnc.com/cnc-machine-...s/fanuc18.html
    Might help...might not is your case,
    DJ
    Feb 2019
    Quote Originally Posted by machinehop5 View Post
    DJ
    Thanks!!! I've tried all of this. The key is I can't find "Tape Mode" anywhere. Switch nor soft key.
