Need Help! Hardinge Cobra 42 spindle drive problem
Results 1 to 3 of 3
Thread: Hardinge Cobra 42 spindle drive problem
    Default Hardinge Cobra 42 spindle drive problem
    I just replaced my magnatek Gpd 505 drive because it took a dump on me. I bought a Yaskawa A1000 drive for it because they said it was plug and play. I knew it was to good to be true! My issue is the parameters in the drive. I don't know what the parameters are supposed to be in the new A1000 drive and I can't copy them from the old Magnatek GPD-505 because it's fried. The previous maintenance guy never saved the parameters on a log sheet so I'm lost. My book doesn't say anything. Any help would be greatly appreciated
    Sent from my Z982 using Tapatalk
    Member Machineit's Avatar
    Mar 2010
    Default Re: Hardinge Cobra 42 spindle drive problem
    Get with this guy. He can probably help you out. He has repaired drives for me.
    Zaritron
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Nov 2008
    Did you ever get the YASNAC to work in your Cobra?
